rancher 350 2006 fan/front end sqeaks
Old Nov 10, 2008 | 12:38 PM
cousinvinny!'s Avatar
Default rancher 350 2006 fan/front end sqeaks
I have rancher 350 used and have 2 problems.
1. Fan never kicks on.
i read the post how to test fan before i do that where is the fuse box
located? what to do if fan wont' test?
2.I have a squeak which sounds like its coming from the rt. shock and it only squeaks with downward pressure.
where can i obtain a mx manual for this 4x4?
thanx
vin
Old Nov 10, 2008 | 03:21 PM
HondaMechanic's Avatar
Here are the tests for the fan ... And the component location including fuse box..
Old Nov 11, 2008 | 09:28 AM
Y2daT's Avatar
nice honda guy,the squeeking means you probly need to lube the shock +a arm bushings...when theese dry out they squeek...Im not sure what lube honda recomends,but I use lithium greese...simply put the front of the quad on a block of some kind remove the front tires ..then unbolt one aarm at a time greese the bushing and bolts and put them back toghther...you should be able to leave the spindels and brakes attached....oh yea do the same to the shocks top and bottom
akguy31
Aug 31, 2019 04:34 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
snowolson
Aug 31, 2015 03:51 PM
