2005 Honda Rubicon Winch
Old Nov 10, 2008 | 10:56 PM
Turtle1231's Avatar
Default 2005 Honda Rubicon Winch
I just bought my first ATV and it's a 2005 TRX500FA. I've wanted one of these for 35 years and finally bit the bullet. I plan to buy a plow and winch but would like some advice. A few questions for you pros.
1. Will any winch fit the TRX500FA with the proper mount?
I noticed it appears to be mounted internally behind the plastic. I hate to order one off the internet and find out it doesn't fit. I only plan to use for plowing. Should I go WARN or go with a cheaper VIPER, GORRILLA etc.
2. Any recommendations for the plow for the ruby?
I'm thinking of going Moose 60 but havn't decided to go with county or standard plow. I found a Moose 60 kit for 485. Will the ruby push a 60 inch plow ok or should I get a 50.
3. Any cons to using a 60 versus a 50 inch plow?
Basically looking for good advice for plow and winch for Ruby! Your help is much appreciated.
Old Nov 10, 2008 | 11:19 PM
cherokee99's Avatar
theres nothing wrong with a VIPER winch. some people nock them, but they are the only ones that are advertized as being completly waterproof. look carefully and make sure the winch you are buying is specifically for your atv, and they will send a model specific mounting plate. alot of winches come with just as much, if not better warrantys than a warn winch, but at half the price.
as far as plows, i dont know why a rubicon wouldnt push a 60" plow. buy a plaw based on the size of your drive way, small driveway= small plow IMO
good luck
Old Nov 10, 2008 | 11:39 PM
Turtle1231's Avatar
My drive is 600 ft. long. I'm considering the Viper or Gorrilla but want something reliable. I'm trying to figure out if WARN and RAMSEY are primarily marketing Hype! I just need a winch to lift a plow up and down. No need for pulling me out of mud holes.
Old Nov 10, 2008 | 11:47 PM
cherokee99's Avatar
iv had a viper winch for 2years, it has served me well. the warranty they offer is equal to warn, im not sure on ramsey. i would be surprised if a viper winch would let you down, because they are older model warn winches themselves! i use my winch frequently and even under water it works with no hesitation.
Old Nov 11, 2008 | 04:16 AM
JeffinTD's Avatar
I've had good luck with Warn, but they are expensive. Warn and KFI both make mount plates for your machine.
I would suggest going with a synthectic cable. As I understand it constantly flexing in the same spot is tough on steel cables.
I don't own a plow, but I would think you would want the 60" so it's path is wider than the ATV's tracks when the blade is angled.
Old Nov 11, 2008 | 10:26 PM
cherokee99's Avatar
i would also go with a 60" plow as well, with a rubi i dont see why not
Old Nov 12, 2008 | 02:57 PM
Turtle1231's Avatar
Thanks for your input. I've decided to purchase a 60 inch Moose plow with a manual lift for now. Most people I've talked to say it's faster and more efficient to use the manual lift versus the winch. If I don't like the manual I'll buy a winch later. I paid $530 for the Moose 60 plow, push tub, mount plate and manual lift. That was the best price I could find.
Old Nov 12, 2008 | 02:58 PM
Turtle1231's Avatar
Does anybody use a manual lift for a Moose plow and if so how do you like it?
Old Nov 12, 2008 | 04:07 PM
hondarider94's Avatar
i posted on ur other thread but,
we use a maunual lift for the 55" state plow and it is faster but after u pull it up and down 100 times it get tiring
Old Nov 14, 2008 | 11:51 PM
Turtle1231's Avatar
Thanks guys. If anyone wants a free Honda Rubicon Repair Manual for the years 2005-2008. There are four downloads left on the link below for 2005 - 2008 Honda Rubicons I purchased off the internet. It's good for 120 hours or 5 total downloads.
https://www.e-junkie.com/ecom/rp.php...&d=28zlh&c=85i
toonces
Oct 19, 2015 02:21 AM
MNatv89
Aug 10, 2015 02:20 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
