yfz450 steering stem bearing.
Old Nov 11, 2008 | 07:33 PM
450speed's Avatar
Default yfz450 steering stem bearing.
first I have an 04 yfz and the steering stem bearing is bad. To remove this you have to take that huge allen lock ring out? Where do you get an allen that big? also any idea if a standard u-joint on a car would use the same needle bearings as the front a-arms do?
Old Nov 11, 2008 | 11:46 PM
beefy46172's Avatar
Loves To Ride!
Well, at the Do-It-Best hardware store I work at we carry allen wrenches up to 1" and 26mm, so if you have one of those or an Ace or True Value around try them. I doubt Lowe's etc would have it.
Old Nov 12, 2008 | 06:56 AM
450speed's Avatar
i was told its a 30 or 33mm.
Old Nov 12, 2008 | 08:05 PM
450speed's Avatar
ya its a 30 mm. So i went to the hardware store and bought a 2 30mm nuts and welded them together and then put a cresent wrench on it and turned it right out.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Sep 23, 2015 06:23 AM
Logan Collins
Sep 5, 2015 08:03 PM
