Gearing question on a 400ex
Old Feb 3, 2001 | 02:12 AM
derekhonda's Avatar
I ride mostly with banshees, and we get out on some country roads and cut through some fields and they absolutely smoke me top end. What I was wandering is is there anyway for me to get in the transmission and make 4th and 5th gear faster? The way I figure it is I only use 2nd and 3rd in the woods, the only time I use 4th or 5th is when we are sustaining high speeds for long periods of times. Give me some info if you know anything about it like costs or what all would be involved or if it can even be done.
Old Feb 4, 2001 | 12:55 AM
derekhonda's Avatar
Oh someone has to have regeared, or know someone who has, comeon.
Old Feb 4, 2001 | 09:24 PM
tprender's Avatar
The only way that you will keep up is to put in a 440 and a cam. You can try one tooth bigger in the front, but I don't think that it will help any. Stay with 20in tires. Best of luck.
Old Feb 5, 2001 | 07:33 AM
FOURWHLS's Avatar
You can get more top end out of your bike but you are going to lose the bottom end. You can change out the front sprocket to a 16 tooth, and drop the rear sprocket down to about a 36 tooth. This should give you a little more speed on the top end, but you are going to be sluggish coming out of the hole. The cost for this change is rather nominal. The front sprockets will run you about $15 and the rear at $30. Give it a try. There's nothing worse that seeing a Honda getting beat by a Yamadog.
Old Feb 5, 2001 | 04:09 PM
derekhonda's Avatar
Yes I know about changing the sprockets out, but in fact I wanted to do the opposite. I want more low end for racing in gears 1,2,and 3. I want 4th and 5th gear to be like highway gears. Anyone else with any info? Also, I am planning to get the gt thunder 440 kit (including everything)
Firefighter400
Oct 8, 2022 06:38 PM
Reactant
Mar 30, 2022 02:08 AM
95wolv
Jul 21, 2015 12:25 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
yambam13
Jul 4, 2015 01:49 PM
