2001 yamaha wolverine 350 coughing at idle
Old Nov 16, 2008 | 02:49 PM
FireNHunt's Avatar
Default 2001 yamaha wolverine 350 coughing at idle
she runs good at high rpms (might still be coughing but i cant hear or feel it). At idle she idles for for about 8 seconds, coughs, idles fine for about 8 more seconds, coughs... and then usually dies. if its choked or revved up higher than idle she doesnt die. I tore apart the card and cleaned it with carb cleaner, as well i sprayed cleaner though while running it (with the filter off, so its not that). And it still coughs.
Any help would be greatly appreciated,
Thanks alot
Zack
Old Nov 16, 2008 | 05:03 PM
cherokee99's Avatar
sounds like a clogged pilot jet. locate the pilot, note how many turns it is in or out. remove, clean, and reinstall the same #of turns in/out as was noted.
the symptoms are common for a clogged pilot jet.
hope this helps you
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 03:10 AM
ranvette
Jul 12, 2015 06:34 AM
Jul 7, 2015 11:00 PM
MNatv89
Jul 7, 2015 11:36 AM
