3 light mod for 800 sportsman
Old Nov 16, 2008 | 11:32 PM
oatman98's Avatar
Default 3 light mod for 800 sportsman
Has anyone checked how many amps all three lights pull when on. I just got my charging system up and running and thinking about doing the light mod. Just dont want to over load the charging system. Has anyone had any problems with it? I use my winch a lot plowing snow. The charging system seems to keep up but dont know with three lights running if that will change.
Old Nov 17, 2008 | 12:23 AM
eggenz7's Avatar
if you winch and run the lights it will probably start to tax the stator. your lights may dim when using the winch but other than that should be ok to run.
Old Nov 17, 2008 | 07:00 AM
700 sportsman's Avatar
If you are going to be doing alot of plowing I would do it using the relay style, because it doesn't draw near as much
Old Nov 17, 2008 | 07:42 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
personally if if it was me i wouldnt use all threee head lights while your plowing as it add that much draw on the charging system. it only puts out like 500 watts reved up i do beleave. imo.
Old Nov 17, 2008 | 08:17 AM
user493's Avatar
Moto Psycho
Do you plow snow so fast you need to see farther down the road? I've had the 3-light mod on several quads and plowed snow with a few of them but use low beam only most of the time. No problems yet. Mine were all 500s.
Old Nov 17, 2008 | 05:57 PM
hddoperator's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 700 sportsman
If you are going to be doing alot of plowing I would do it using the relay style, because it doesn't draw near as much</end quote></div>
Using a relay don't reduce the load it just doesn't put it all on the headlight switch.
The relay is used to help protect the light switch nothing more.
Old Nov 17, 2008 | 06:52 PM
O ok I mis understud you other posts
thanks for the correction hdd
bzdok1234
30
Feb 23, 2016 01:55 PM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
