plowing and winch rope
Old Nov 17, 2008 | 08:46 PM
700 sportsman's Avatar
Default plowing and winch rope
with my front brushguard on my winch rope rubs my bumper, and last year I put a piece of rubber belting over it so it wouldn't rub, but eventually the rope broke,
would there be anything wrong with making an extended fairlead, that would put the rope out past the bumper
any other ideas are welcome
thanks in advance
Old Nov 17, 2008 | 10:06 PM
Koerbs's Avatar
I have tons of clearance from my brushguard to my winch rope...... Oh I see now you have a warn plow, I would make some sort of a deal that is on the plow that keeps the rope away from the brush guard. Like a mini pully with a 6 inch rope attached to the plow blade at the top, run your winch rope through the pully and it should change the angle enough to stop your problem.
Old Nov 17, 2008 | 10:12 PM
thats a good idea I'll have to think about that
any other ideas
Old Nov 17, 2008 | 10:19 PM
rancher55's Avatar
You could just put a V shaped roller on the bumper where the rope wears against it.
Why do you guys use rope instead of cable? more length ? Just wondering.
Old Nov 17, 2008 | 10:22 PM
its stronger overall, and plus if it breaks it doesn't build up kinetic energy so it won't lash out if it would break like steel cable would
Old Nov 17, 2008 | 10:29 PM
rancher55's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 700 sportsman
its stronger overall, and plus if it breaks it doesn't build up kinetic energy so it won't lash out if it would break like steel cable would</end quote></div>
Thanks 700 sportsman,
How much stronger is it than cable? I understand the safety aspect!
Old Nov 17, 2008 | 10:37 PM
I can't remember exactly, but I know its at least twice as strong, but I think its more toward 3 times stronger
Old Nov 17, 2008 | 11:18 PM
user493's Avatar
Moto Psycho
Can you put a spacer between the winch and the fairlead? A steel bracket maybe?
Old Nov 18, 2008 | 07:13 AM
thats what I was thinking Jumbo, but I wandered if that would put strain on anything, or mess it up
Old Nov 18, 2008 | 07:30 PM
any body else have any ideas
