klf 220 wiring diagram help needed
Old Nov 19, 2008 | 07:26 PM
rgarbrandt's Avatar
Default klf 220 wiring diagram help needed
i just bought a 92 bayou klf 220 that runs and looks like new.BUTthe starter doesnt engage unless i applie direct power to it. it seems the wiring is hacked up on it.from the positive post the cable goes to selonoid and the other side of it goes to ground. the negitive side othe the battery goes to the starter.the relay just buzzes when trying to crank it. good thing the pull starter works.i believe the wires are crossed.if i get the starter to ever work i will still need to repair something internally in the engine because when hot wired it the starter spins but nothing happens. any wire diagrams that could be sent would greatly apprieciated
Old Nov 19, 2008 | 10:36 PM
Hayashi's Avatar
More than likley, it is the poor ground wire (blk) connection from starter relay to the frame if the wiring harnes on your quad is in orignanl condition.
If my memory serves correctly, it is on the LEFT side as you are sitting on the bike. I think it is either 8 or 10 mm head bolt you have to remove to disconnect the wire lead from the frame. Then, sand off paint/corrosion from the frame and reconnect.
Old Nov 19, 2008 | 11:47 PM
rgarbrandt's Avatar
all sounds good about the ground connection but when the selonoid is engaged woulded that be a direct short . or is the starter operated on a ground rather than a hot wire to complete the circuit??
Old Nov 20, 2008 | 12:25 PM
Hayashi's Avatar
Do a search on this forum on this problem if not done so, and see what you find.
tiresharkdbb
Sep 3, 2017 02:06 AM
jag6510
Jun 15, 2015 05:59 PM
wildbill59
Jun 9, 2015 02:28 AM
clsharky
Jun 8, 2015 11:38 AM
Icedevice
May 25, 2015 08:38 AM
