CV Boot Replacement
Old Nov 21, 2008 | 02:08 PM
Polaris5's Avatar
Default CV Boot Replacement
I am trying to replace a torn front outer CV boot on my 2005 Sportsman 500. I got everything tore down, except I'm having trouble pulling the outer CV joint off the shaft/axle. How do I do it?
Is there a snap ring inside the CV joint I have to find? If so, can I remove the snap ring with a standard snap ring pliers?
Is there a spring clamp inside the CV joint in which I should just pound the CV joint off with a rubber hammer?
Thank you
Old Nov 21, 2008 | 03:23 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Hit it with a hammer. It will pop off and on with a litle force.
Old Nov 21, 2008 | 03:33 PM
jlegger's Avatar
Polaris 5,
If you will clean the grease out of the joint next to the axle you will see a retaining ring next to where the cv joint attaches to the axle. I used a set of snap ring pliers to spread it open and my son knocked it off the axle with a hammer. Do a search and there are several good articles on replacement of the boot and cv joint. There is even a video on you tube that someone had a link to that is very helpful.
Good luck,
Old Nov 21, 2008 | 04:12 PM
teamplayer's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jlegger
Polaris 5,
Good luck,</end quote></div>
I think that clip is only for the rear cv?
On mine there is a spring clip on the fronts, as said earlier, just smack it with a mallet.
Old Nov 21, 2008 | 04:17 PM
jlegger's Avatar
Your right I was referring to the rear....my bad!
Old Nov 21, 2008 | 06:47 PM
btatum's Avatar
Search youtube for cv boot replacement... there's tons of info...
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
