05 700
Old Nov 21, 2008 | 04:28 PM
jlegger's Avatar
Default 05 700
I have an 05 twin 700 and there is some excessive play in the drive shaft between the transmission and the rear gear box. I am contemplating changing out the u-joints but was just curios as to how complex the job would be. Does the gear box have to come out to remove? Can you replace the u-joints like the old automobile u joints or do you have to replace the yoke and all?
Old Nov 21, 2008 | 09:21 PM
Default 05 700
Rear propshaft has kits to rebuild,but check parts and labor(even your own) versus new propshaft assy.Rear gearcase must be moved back/removed to allow room to remove/ install propshaft. Spring pin must be removed at transmission end and knocked backwards to remove/ install. Similar to car u-joints.
Old Nov 24, 2008 | 01:21 PM
jlegger's Avatar
Default 05 700
Hey Thanks OPT!
Your knowledge is most helpful!
