how do remove a Hoda 450 foreman front differential
You just remove the 3 mount bolts and the front mount .. Slide it all the way forward and remove the drive shaft you may have to use a large screwdriver/prybar to compress the drive shaft spring a little ...
ok thankx ill try it-cause ive removed the three mount bolts but couldn,t get it out the chasis. waz wondering if i might have to slide the engine back?!
if all else fails remove the frame a arm bolts from one side ( i did the left side on my 300 fw)..this will give you more room to pop out the cv shafts there held in with a ring that makes them snap in and out ..you may need a prying device here as well or juist a good ******,to remove the cv shafts
JackTheKing
Jul 14, 2015 09:09 PM
