how do remove a Hoda 450 foreman front differential
Old Nov 22, 2008 | 07:20 PM
Goober1989's Avatar
Default how do remove a Hoda 450 foreman front differential
the front differentil is loked up so im replacing it with a new one but i cant the darn thing out. i know there a way.
Old Nov 22, 2008 | 11:31 PM
HondaMechanic's Avatar
You just remove the 3 mount bolts and the front mount .. Slide it all the way forward and remove the drive shaft you may have to use a large screwdriver/prybar to compress the drive shaft spring a little ...
Old Nov 23, 2008 | 01:26 AM
Goober1989's Avatar
ok thankx ill try it-cause ive removed the three mount bolts but couldn,t get it out the chasis. waz wondering if i might have to slide the engine back?!
Old Nov 23, 2008 | 01:48 AM
cherokee99's Avatar
you dont have to move the engine, the drive shaft can be compressed a ways. like hondamechanic said, just move the front diff forward
Old Nov 23, 2008 | 12:17 PM
Y2daT's Avatar
if all else fails remove the frame a arm bolts from one side ( i did the left side on my 300 fw)..this will give you more room to pop out the cv shafts there held in with a ring that makes them snap in and out ..you may need a prying device here as well or juist a good ******,to remove the cv shafts
JackTheKing
Jul 14, 2015 09:09 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
