nuke wheels and offset question
Old Nov 22, 2008 | 11:45 PM
gaugedholes's Avatar
Default nuke wheels and offset question
this is what it says..quot.The 12x7 and 14x7 with the +10mm offset (4+3) wheel is used on the front of all ATVs and the rear of ATVs with Independent Rear Suspension......and....
The 12x7 and the 14x7 -47mm (2+5) offset wheel is used on the rear of ATVs with a Solid Rear Axel....why couldnt you put the wide offset like for the soild axle on indepedent suspension???
Old Nov 23, 2008 | 12:57 AM
ANYONE??? HELP!!!!
Old Nov 23, 2008 | 07:17 AM
user493's Avatar
Moto Psycho
You CAN put a wider offset on it. Whether you <u>should</u> or not is another question.
Old Nov 23, 2008 | 11:11 AM
like what would happen if i would???? any stress on anything?
Old Nov 23, 2008 | 11:59 AM
HIGHOCTANE's Avatar
A wider offset always puts more stress on components such as ball joints(Front and IRS) and wheel bearings. The nature of the solid axle makes it less susceptible to the added stress,but it still adds stress to the axle(wheel) bearing. How much stress depends on the offset. Also with IRS the added offset affects suspension geometry and puts more load/leverage on the shock/spring. So if your spring isn't adjustable you will notice more sag and it most likely will feel mushy. When I went from stock to 4+2 front and 5+3 rear I had to turn up the springs 2 clicks front and rear. And that isn't near a 2+5 offest.
Old Nov 23, 2008 | 12:07 PM
MECHANIKE's Avatar
I HAVE 1-1/2" SPACERS ALL AROUND, GOT TIRED OF TURNING CORNERS ON THE SIDE TIRES,YEAH THERE IS MORE STRESS, BUT I DON'T CARE,HENCE THE NAME MECHANIKE.......
Old Nov 23, 2008 | 12:18 PM
so it should be ok??? the offset of the wheel looks so good with the 5inch dish....i just dont wanna be tearing anything up...wheel bearings are my last worry..fender issues dont matter either..cuz the lift is comming real soon...here is the link to the wheels and yall let me know what yall think about the wheel with and without the offset...and if it will fit and work 4 me...thanks guyes!!!http://traxms.com/ATV_Wheels_Utility_MS_Nuke.html
Old Nov 25, 2008 | 12:20 PM
ANYONE???
Kyle5050
Dec 13, 2019 04:25 AM
Bergmann
Aug 13, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
Jul 21, 2015 03:03 PM
yambam13
Jul 4, 2015 01:49 PM
