Recon keeps dying? Help...
Old Nov 26, 2008 | 10:42 PM
Kcolg's Avatar
Default Recon keeps dying? Help...
Have a 2001 Honda Recon and a friend was riding it and crashed into a tree. No serious injuries, but the Recon wants to die sometimes while idling and especially if attempting a steep climb, no matter how small such as a small creek or deep ditch. Shortly after nosing it up the hill it will die on me. And as stated sometimes it will even do it when I'm in idle on flat ground.
Anybody know what to check or fix or whatever? I can turn a wrench, but honestly don't know where to start.
Any help greatly appreciated.
Old Nov 26, 2008 | 11:27 PM
cherokee99's Avatar
sounds like a carb issue. open up the bottom of the carb and test the float. there is a small pin that holds the float in place, you will have to remove that carefully. dont loose the pin! take off the float and submerg it in water. hold it underwater for a few seconds before you take you hand away. if it rises your float is good, but if its bad it will sink, or there will be water inside.
this is a good place to start
Old Nov 28, 2008 | 01:16 PM
Kcolg's Avatar
Will give it a try, thanks.
ultangler
Nov 30, 2024 01:35 AM
Pehter
Oct 3, 2024 11:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
2many2ride
Sep 27, 2015 04:35 AM
Jason Campbell
Sep 7, 2015 02:25 PM
