warrior shorted battey now no spark!!!
Old Nov 27, 2008 | 07:57 PM
Y2daT's Avatar
Default warrior shorted battey now no spark!!!
i did a wheelie on my 94 warrior and the battery shorted out ....now it has no spark ? does anyone Know what to check?or have a manual with the electrial trouble shooting info.....
Old Nov 27, 2008 | 08:04 PM
91Warrior357's Avatar
the rubber fuse holder under the left fender i think its a 15 or 20 amp fuse see if its blown
Old Nov 28, 2008 | 06:51 PM
Y2daT's Avatar
its been bypassed no longer there
i think the cdi is fried ....shows ground on hot wire supposed to be infanate..weather kill switch is off on on same result
Old Nov 29, 2008 | 12:14 AM
wow bypassing that is a bad choice...its there to prevent parts like the cdi from frying...its got a red wire going to and from it and its black shaped like a big pill you just twist and pull it off, hopefully you have one and can just change it otherwise thats no good.
Old Nov 30, 2008 | 08:00 AM
cadillacdude1975's Avatar
yeah that is bad. the fuse is designed to take the impact of a short running through the electrical system. now the next stop for that short would be the CDI box.
Old Nov 30, 2008 | 12:29 PM
Y2daT's Avatar
yep the cdi seems fried ..im in the market for a un mulitated wire harness and good cdi.....( the fuse was aparently removed by a previous owner) thanx for your help guys
Old Dec 1, 2008 | 04:18 PM
Trail Tender's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Y2daT
yep the cdi seems fried ..im in the market for a un mulitated wire harness and good cdi.....( the fuse was aparently removed by a previous owner) thanx for your help guys</end quote></div>Can you tell me how to test the statter and the coil on a 87 warrior thanks.
Old Dec 2, 2008 | 03:23 PM
ohms and resisance test.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
