mirrors for the 850 XP
Old Nov 29, 2008 | 04:20 PM
vegasdude's Avatar
Default mirrors for the 850 XP
I'm looking for Mirrors for the XP. Are the handle bars the same as the 800 EFI? I have mirrors on my 05 800 EFI and I really like them.
Old Nov 29, 2008 | 05:04 PM
HIGHOCTANE's Avatar
Bars are not exactly the same but I think the diameter is the same. I know the Polaris mirrors in the 2009 says "fits all ATVs". I bet they will work.
Old Nov 29, 2008 | 05:54 PM
vegasdude's Avatar
Hey thanks, I'll give them a try!
Old Nov 29, 2008 | 11:56 PM
RticKwad's Avatar
Runs Stealth!
If you buy the Polaris bar end mirrors you may think you are missing
something but you are not. It is a weird tension nut design so when
you insert the end in and as you turn the top with the allen wrench the bottom end will do a twist turn to catch inside the hollow of the handbars to hold it.
As for me I have my installed on my Sp800 on the top over the winch rocker switch as I won't have to worry about trees or other brush when I go thru tight areas. My only mods were to get a longer lag screw, wash and nut and go thru the Rocker switch assy. and the brake assy. I think I also added a 1 inch small 1/4 inch plastic spacer. You can get all of it at any hardware store for like pennies to about $5.00 if that.
R'
Old Nov 30, 2008 | 03:03 AM
vegasdude's Avatar
Hey thanks, I appreciate that!
MikeyBoyesq
Nov 27, 2020 02:44 PM
greg74
Sep 10, 2019 03:03 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
duneittilludie
Mar 2, 2004 02:01 PM
BigD500ho
Jul 20, 2003 09:14 AM
