Namura Piston
Old Nov 29, 2008 | 11:03 PM
bellanca guy's Avatar
Default Namura Piston
I am going to replace the piston when I put it back together. Mine is .010" over already and the cylinder specs good at 1st over. Question, Honda OEM, Namura or Wiseco? I am leaning towards the Namura but know nothing about them. Anone use these pistons?
Old Dec 1, 2008 | 01:59 AM
Duster_440's Avatar
Just did a full top end on my 400 which now is a 440.
I dropped in a namura 440 piston
a namura sleeve and the full namura top end gasket set.
i went ahead and sleeved it b/c i didn't want to mess with it again it was 55 for the sleeve and about 170 or so to have it installed.
i'm still working on on tuning but from what i see it namura is just as good as any wiseco.
i'm sure you've read all the info on both sides and the two main reasons i went w/ the namura piston:
treated piston head.
price.
i've got a buddy that is putting a couple banshees together and he called up namura and they hooked him up.
according to the namura guy they are placing a special coating ( derived from NASA) that helps breakin and longevity of the piston as well as a treated piston head that is to allow for a 300% gain in durability compared to a standard aluminum piston.
the piston price was noticeably less that a comparable wiseco
i know that wiseco has a special coating now but i don't believe that the piston head is treated.
like i said everything went together solid and the namura is there to help if you need it.
i probably wouldn't go w/ oem.....
Hope this helps any other questions let me know....
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
