Polaris trailblazer noise when turning??????
Old Nov 30, 2008 | 03:25 AM
quepasa69's Avatar
Default Polaris trailblazer noise when turning??????
I just bought a 98 Polaris Trailblazer and when ever I turn or really get on it I am getting a noise like gears grinding. It also does it when I load it into my truck. I am guessing it is in the gear case. The chain will bounce a little when it does it but it doesn't slip. Also the axle appears to be straight. Not sure if I should attempt to pull the gear case and check it out. Is this a common problem? Anyone with any ideas is appreciated!!!
Old Nov 30, 2008 | 10:07 AM
Kerbbirds's Avatar
Could be the silent chain is stretched in the tranny, have to remove tranny to repair, a service manual spells out how to.
Old Nov 30, 2008 | 12:21 PM
eggenz7's Avatar
its not a hard job to do either. not much in that gear case.
since your going to be in it anyways i would suggest replacing the seals on the gearshafts too.
Old Nov 30, 2008 | 02:22 PM
91Warrior357's Avatar
before u do that, look under ur swingarm and to the left of the bottom of the chain and there will be a piece of metal sticking out right there that is suppose to have a roller or something, if its not there than thats ur prob when ur chain tightens it will rub against that metal making it sound like a tranny or rearend prob.
Old Dec 1, 2008 | 10:10 PM
quepasa69's Avatar
Thanks guys for the advice, I will get started! Might be back here with more questions. Thanks!
whitty
67
Feb 24, 2021 02:52 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
3quadbob
Sep 18, 2016 09:46 PM
FourWheelOverTwo
May 31, 2015 07:26 PM
Faraday
Feb 11, 2001 09:28 PM
