2000 Sportsman 500 hub oil change
Old Dec 1, 2008 | 08:37 PM
chikester's Avatar
Default 2000 Sportsman 500 hub oil change
Can someone tell me how to change the hub oil on my Sportsman. What type of oil do I need as well. Thanks.
Old Dec 1, 2008 | 09:00 PM
highwayman's Avatar
I use synthetic ATF for hub oil. I jack up the front and take off both front wheels and take out the set screws in the hub and drain. I fill them up to the top and put the set scews back in loosely and rotate the hubs and drain.( I do this a couple of times) then fill again and drain with hole at 4 o'clock. Put set screws back in and away you go. You can also buy Polaris Hub Fluid but I like ATF
Old Dec 1, 2008 | 09:02 PM
3/16" allen plug for drain and fill. Drain fluid,refill with demand drive hub fluid(atf in a pinch),turn opening to 4oclock position,let excess drain until quits or slow trickle,then reinstall allen screw.
Old Dec 1, 2008 | 09:11 PM
chikester's Avatar
hate to sound stupid but what is ATF? Is this automatic transmittion fluid?
Old Dec 1, 2008 | 10:19 PM
highwayman's Avatar
Yes, Automatic Transmission Fluid
Old Dec 2, 2008 | 02:12 PM
Wheels47's Avatar
Make sure you know the torque for the drain plug. I think it is 14fp it seems like it can strip the theads easily if tightened to much.
Jmuddin284
Jan 19, 2026 07:16 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
