Winch and 4x4 will not work
Old Dec 1, 2008 | 09:34 PM
Marksvilleman10's Avatar
Default Winch and 4x4 will not work
Hi All,
Can anyone tell me why a winch and 4x4 would just all the sudden stop working? Battery has enough power to electric start the machine. Any help would be appreciated.
Thanks
Old Dec 1, 2008 | 10:23 PM
rancher55's Avatar
Sounds like an elec. problem. Have you checked your fuse box?
Old Dec 1, 2008 | 11:36 PM
Have not. This is on my uncles machine. Any idea where the fuses would be located on a 1999 sportsman 500
Old Dec 2, 2008 | 07:23 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it does not have a fuse box. check the awd light bulb to make sure its not blown, or there is power to it. make sure the winch connections are good and ther is no bare rubbing wires which would short out the electrical system.
Old Dec 2, 2008 | 10:56 AM
Groovy's Avatar
I found this on another forum hope it helps.
http://forums.atvrideronline.c...fuse-panel/index.html
the sportsman 500 1999 does not have fuses.
it has resettable relays.
looking down at the battery go toward the front about 5 inches and there should be a black pouch.
what happens is this pouch normally gets full of mud and falls apart.
but you should find the relays there and be able to reset them. (just make sure you dry it out good first. you can also try to water proof it a little with some aquarium silicon
Old Dec 2, 2008 | 11:16 AM
Thanks everyone. I will let him know. Much appreciated.
hugemoth
Jul 20, 2020 03:28 AM
timster911
Jul 13, 2015 01:57 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
bikedad3
Jul 2, 2015 02:15 AM
