honda 400EX starting problem
Old Dec 3, 2008 | 11:07 PM
Honda400-4-ever's Avatar
Default honda 400EX starting problem
when i try to start my 2005 honda 400ex it wont start. all it does is start clicking. i tried to turn on the lights and they worked. what is wrong???
Old Dec 3, 2008 | 11:26 PM
Loshe191's Avatar
It could be a couple things it may be the starter solenoid, or it could be a loose or dirty battery terminal.
Old Dec 4, 2008 | 12:06 AM
brungardt's Avatar
it may new a battery and the lights turn on but not enough power to crank it..(the clickin) how bright are the lights?.... take it to the top of a hill while ur on it let it get going as fast as it will go and drop it from nuetral into 1s... if it starts u need a battery
Old Dec 4, 2008 | 12:07 AM
brungardt's Avatar
it may need a battery( correction)
Old Dec 4, 2008 | 06:20 PM
Y2daT's Avatar
i answered prob the battery in the other thread ,coroded or loose connections can cause this as well
Old Dec 4, 2008 | 08:52 PM
THE LIGHTS ARE VERY BRIGHT
Old Dec 4, 2008 | 09:52 PM
moto134's Avatar
tap on the starter when you are pushing the start button
Old Dec 5, 2008 | 04:55 PM
wheres it at?
Old Dec 5, 2008 | 07:48 PM
Duster_440's Avatar
Under the carb to the back of the bike....
With an 05 i'd to think the the starter hasn't gone out.. but id like to think the solenoid before the the battery or the starter....
you could bypass the solenoid ONLY to see if it engages the starter. ....
Old Dec 5, 2008 | 08:16 PM
well something wierd happend i hooked it up to the charger and it started so i know that the battery just needed to charge and when it started i hit the throttle something started to smell like it was burning but i thing it was that i didnt let the oil to circulate and the metal in the engine was rubbing.
Land_shark1
Jul 10, 2015 12:53 AM
DTroyer01
Jul 3, 2015 07:34 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
roktoy
Aug 25, 1999 04:37 PM
