honda 400EX starting problem
it may new a battery and the lights turn on but not enough power to crank it..(the clickin) how bright are the lights?.... take it to the top of a hill while ur on it let it get going as fast as it will go and drop it from nuetral into 1s... if it starts u need a battery
Under the carb to the back of the bike....
With an 05 i'd to think the the starter hasn't gone out.. but id like to think the solenoid before the the battery or the starter....
you could bypass the solenoid ONLY to see if it engages the starter. ....
well something wierd happend i hooked it up to the charger and it started so i know that the battery just needed to charge and when it started i hit the throttle something started to smell like it was burning but i thing it was that i didnt let the oil to circulate and the metal in the engine was rubbing.
DTroyer01
Jul 3, 2015 07:34 AM
