2008 rincon
Old Dec 4, 2008 | 08:22 PM
bambam101's Avatar
Default 2008 rincon
i need help i have a rincon that will not start and the F1 light flashs 9 times need help bad
Old Dec 4, 2008 | 09:08 PM
JeffinTD's Avatar
Default 2008 rincon
Welcome to the forum.
It should show long blinks and short blinks. 9-1 is low voltage at IAT sensor. 9-2 is low voltage at IAT sensor.
Old Dec 4, 2008 | 09:26 PM
bambam101's Avatar
Default 2008 rincon
It was fast blinks what how do I fix it
Old Dec 4, 2008 | 10:40 PM
JeffinTD's Avatar
Default 2008 rincon
I suppose the first thing I would do is check that the plug for the IAT is clean, dry and tight.
If the IAT sensor input was out of range, the engine should run, so I'm wondering if that really is your problem...
Old Dec 4, 2008 | 10:47 PM
bambam101's Avatar
Default 2008 rincon
Where is this sensor cause it was put in water and this is when I. Stated having problem
Old Dec 4, 2008 | 10:56 PM
JeffinTD's Avatar
Default 2008 rincon
IAT is intake air temp sensor. It is mounted on the air box.
If you are going into deep water much, it would be a good idea to unhook the battery, then take apart every connector you can find to clean them with contact cleaner if needed, blow out any water or dust with an air compressor, and pack the connector with some diaelectric grease and reassemble...
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
rgjackson
Sep 23, 2015 01:53 PM
Pissed off
Sep 21, 2015 02:33 PM
poutlaw525
Sep 9, 2015 03:19 AM
