yamaha breeze 125
i have a 99 breeze with a new starter new carb new battery. it wont crank, unless i put my battery charger on it and set it to 40 amps to crank it. when it runs it runs great. i'm not sure what the compression should be. when i did a comp. check it would go to 50 and drop as i hit the start button sometimes it would hit maybe 20 or 30 then drop to 0 compression as i hold the start button downgrants
<div class="FTQUOTE"><begin quote>Have you checked all the cables and connections? </end quote></div>
What he said.
Also it sounds like you have a problem with the foot valve on your compression tester. It should never drop unless you have a bad foot valve or don't have on on the tester at all.
What he said.
