yamaha breeze 125
Old Dec 6, 2008 | 02:51 PM
rockinrodtex's Avatar
Default yamaha breeze 125
i have a 99 breeze with a new starter new carb new battery. it wont crank, unless i put my battery charger on it and set it to 40 amps to crank it. when it runs it runs great. i'm not sure what the compression should be. when i did a comp. check it would go to 50 and drop as i hit the start button sometimes it would hit maybe 20 or 30 then drop to 0 compression as i hold the start button downgrants
Old Dec 6, 2008 | 03:15 PM
91Warrior357's Avatar
so by that u mean the enigne will turn over but not start up? or it wont turn over at all?
Old Dec 6, 2008 | 05:03 PM
it will turn over but it wont start unless i kick the batt. charger to 40 amp.
Old Dec 7, 2008 | 12:22 AM
Traildad's Avatar
Have you checked all the cables and connections?
Old Dec 7, 2008 | 01:41 AM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>Have you checked all the cables and connections? </end quote></div>
What he said.
Also it sounds like you have a problem with the foot valve on your compression tester. It should never drop unless you have a bad foot valve or don't have on on the tester at all.
Old Dec 9, 2008 | 11:28 AM
yes i checked all conn. they are good. i'm gonna check my guage
black_thunder
Sep 22, 2015 07:59 PM
CosmoM
Sep 21, 2015 04:57 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
