500 scrambler
Old Dec 7, 2008 | 08:02 AM
farvaman's Avatar
Default 500 scrambler
ok hi how is everyone good i hope ok i have a 500 scrambler bought a new belt i have about 10hrs on it i herd a whipping sound and then found out my belt came apart i took it out and called the dealer and asked if it might be defective he said bring it in ANYWAYS i took it to a friend and he sais insted of buying a new one just turn it around and see what happens so i did went riding yesterday and it was fine until i real started pounding on her then i heard that sound again and sure enough it started ripping the belt apart could i of just got a bad belt or should i try a DAYCO belt dont know much about clutch it looks like it operates ok any help if so get back to me ty FARVAMAN
Old Dec 7, 2008 | 10:44 AM
ftwflh's Avatar
The belts are direction al once you install them.Always put on where you can read the writing.You never flip one it wont last.
The stock belts are your best bet.
Old Dec 7, 2008 | 10:53 AM
MECHANIKE's Avatar
Make sure you clean all the old pieces out.
Old Dec 7, 2008 | 10:55 AM
rancher55's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
The stock belts are your best bet.</end quote></div>
Also the clutches have to be aligned properly or you will wear the belt too quickly!
If you're not sure, have the dealer put it on and check it for you.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 7, 2008 | 10:58 AM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: rancher55
If you're not sure, have the dealer put it on and check it for you.[img][/img]</end quote></div>
This is not ussually an issue unless you have had the engine and/or the tranny out.
Most belt failures are from abuse like getting stuck,pulling or water.AKA smoking a belt
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
