warrior no spark
Old Dec 7, 2008 | 01:32 PM
kingaling73's Avatar
Default warrior no spark
i just changed the starter clutch and flyweel on a warrior now i have no spark it ran before i changed it ne help would help greatly thanks
Old Dec 7, 2008 | 03:13 PM
91Warrior357's Avatar
double check your stator connections and make sure everything is the way it was. what all did u take apart and how?
Old Dec 7, 2008 | 03:59 PM
i pulled off cover but left all the wires hooked up pulled the clutch and flyweel the bearing and flyweel were bad so got the clutch and flyweel off ebay put the whole thing on and put back together now it roll over but it dont have spark. im going to try to change the bearing and flyweel
Old Dec 7, 2008 | 04:56 PM
did u purchaset hese brand new? and by flywheel do u mean the stator hub( the thing the stator sits inside of) or did u actually replace the flywheel? the flywheel is a darker color with teeth and the stator hub or magneto wutever u wanna call it is shiny. if u ordered a used magneto it might be bad if its lost its magnetic power or it has alot of scrapes or dings in the inside of it that might do it. the lights and everything still work though? im just trying to figure out what could have possibly happend
Old Dec 13, 2008 | 11:12 PM
taylorteamracing's Avatar
well im ready to part my warrior out the flippin thing wont run either i chaged the stator pick up coil primary coil ignition coil reset the mechanical timing new plugs and it wont run off of gas or either but the spark is bright blue and steady
96 warrior
87 lt250r
96 lt160
150cc mini buggy
baja bike
yz125
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
