Torn CV Boot
Old Dec 9, 2008 | 02:31 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Default Torn CV Boot
Found a torn CV boot last night while changing oil. Joint requires cleaning before repacking with grease. What is the best cleaner / method to clean the CV?
Old Dec 9, 2008 | 04:00 PM
Deerkiller's Avatar
I'd check some past threads on this forum back about 3 months.
You'll want to take the hub assembly off and change boots. clean it up while it's apart.
Any grit in there is going to tear it up.
Old Dec 10, 2008 | 10:23 AM
miande's Avatar
I did one last month. It was my first time. My opinion, completely disassemble the CV joint. Remove the cage and bearings. Be careful to note which side of the cage is up. Found a good video on Youtube of a guy disassembling the joint. At first, it does not seem like it will come apart but keep working at it. Once it is apart, clean it up with soap and water. Use a good diswashing detergent as they are designed to dissolve grease and do not leave behind a film like some solvents. They rust fast so be ready to reassemble before you take it apart for cleaning.
I tried 3 different brands of aftermarket boots and felt the fit was poor. I eventually went with the OEM and there was a noticeable difference in the fit. Some of the aftermarkets may be thicker but they just did not fit as snugly as the OEM.
Good Luck.
Old Dec 12, 2008 | 11:05 PM
war1ock's Avatar
I used both kerosene and diesel fuel and left to sit for 24 hours to soak and that cleaned em up nice
Old Dec 13, 2008 | 09:59 AM
big_kid's Avatar
i used to get the neighborhood kid to clean all my parts in kerosene. told him he would get to ride after the job was done. worked every time.....
Alex G.
Sep 11, 2017 11:38 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
