1994 400L no gas at spark plug
Old Dec 9, 2008 | 09:27 PM
soccer08's Avatar
Default 1994 400L no gas at spark plug
1994 polaris 400L 4X4 2 stroke
gas at carb, spark at plug, but wont start. the plug stays dry.
any suggestion?
Old Dec 9, 2008 | 10:06 PM
eggenz7's Avatar
if its been sitting there could be a rats nest in the jub ports. have you tried spraying starter fluid directly into the cylinder while turning it over? carb could also be gummed up from sitting.
let us know what all you have done to it so we can get a better idea of where the issues stand at
Old Dec 9, 2008 | 10:21 PM
ftwflh's Avatar
Clean carb,check reeds,check compresion
soccer08's Avatar
it died while idling.
i noticed fuel leaking from the carb.
the bowl had a pin hole leak so i put JB weld on it.
sprayed everything down inside with carb clearner.
reinstalled carb
(wont run) plug stays dry even if i work the throttle while trying to start
Old Dec 9, 2008 | 10:22 PM
soccer08's Avatar
what are reeds?
Old Dec 9, 2008 | 10:31 PM
eggenz7's Avatar
if you take the carb off they are the little plastic flaps you see going into the motor. they are usually the only valves on a 2 stroke motor.
are you sure you getting fuel into the float bowl. lightly unscrew the 17MM bolt on the bottom of it while the fuel line is hooked up. see if fuel starts trickling out of there. if it is, then i would take the carb apart and make sure there isnt a blockage somewhere causing the fuel to stop getting into the carb body.
if it died while idling, what does the end of your spark plug look like? is it white/ashy looking. might have burned a hole in the piston.
agree with ftwflh i would check compression
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
