Timberwolf sounds
Old Dec 9, 2008 | 09:57 PM
Joeleo2010's Avatar
Default Timberwolf sounds
i own a 1994 yamaha timberwolf, and i got it professionally serviced by a local dealer around a year ago, ever since i got it back it sounds like the engine is a little noisy. When its running, it sounds like it "clicks" idling, and then the clicking speeds up when it's revved. I put a new exhaust on it and the noise got a little better, but it dont know if it's something to do with the piston or something caught in the cylinder.It hasn't given me any problems and hasn't seemed like it is lacking power, but im selling it and dont know if that sound is regular for older atv's like mine or if i need to get into the engine and do some work. any help would be appreciated...thanx
Old Dec 9, 2008 | 10:10 PM
joaquin's Avatar
It hapened to me a couple of years ago with my old Timberwolf 96. It was the camshaft and the camshaft bearing. They were worn. They changed it, and problem solved, maybe you have the same problem...
beefy46172's Avatar
Loves To Ride!
Sounds like valvetrain noise, normally just the rocker arms hitting the valve springs. Some motors make more noise than others in this regard, but it may not hurt to check your valve adjustments just to be sure they are ok.
Old Dec 9, 2008 | 10:25 PM
Joeleo2010's Avatar
alrite, ill have to get it checked out, thanks alot for the help guys!
Old Sep 23, 2010 | 06:01 AM
budd68's Avatar
did you say the noise came back with the atv when you had it worked on?
Old Sep 23, 2010 | 06:58 AM
dirtjunkie's Avatar
you realize this thread is 2 years old ?
exmotocrosser
Sep 13, 2019 06:12 AM
flyin-lowe
Dec 1, 2017 03:18 AM
mrtidy
Feb 3, 2016 05:00 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
