400 foreman
Old Dec 10, 2008 | 01:47 AM
A1's Avatar
A1
Default 400 foreman
While on my way to get a camera to take pics of the motor after taking the case apart the motor got turn over dumping out some parts, now I don't know what goes where. Does anyone have a repair manual that could give me a hand at putting it back together? I would need the engine section and could use the section on rebuilding the clutch.
Jason
Old Dec 10, 2008 | 02:27 PM
Gimpster's Avatar
Default 400 foreman
For a parts microfiche break-down of the engine, check out Ronnie's microfiche or Ron Ayers. Make sure the transmission shifts through all gears and that the main and countershaft spin as they should in each gear before putting the engine cases together. There is one gear in the transmission that looks the same if installed eather way around. If it is installed the wrong way you will be taking the cases apart again. There is only a few millimeters difference in the off-set and has bitten a lot of people when reassembling this engine platform
----- Gimpster -----
Old Dec 10, 2008 | 04:53 PM
HondaMechanic's Avatar
Default 400 foreman
Just PM your email address if you still need any shop manual sections..
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
highwayman
Sep 19, 2015 12:59 PM
patrick.oc123
Sep 15, 2015 02:45 PM
