Issues with a 01 Bear Tracker
Old Dec 11, 2008 | 12:27 AM
Oct7brian's Avatar
Default Issues with a 01 Bear Tracker
I've had a 01 Beartracker for several years now and was thinking about handing it down to my son for x-mas but and dealing with a running issue. I pulled that carb and diped it as well as replaced the needle and seat. The carb was dirty but not as bad as I thought. I took it out this evening for a test run and it ran great around the yard but when I tried to drive up the hill it wanted to die out. As soon as I returned to level ground it was fine again. Any ideas???? Also does anyone know what the compression reading should be??
Old Dec 11, 2008 | 04:25 PM
91Warrior357's Avatar
compression should be somewhere around 140 but it varies on what model you have, and it sounds to me like your maybe having a float problem, try to carefully inspect it and make sure its moving up and down freely and not sticking, also the pin that holds the float in sometimes there not in there all the way or they are lose and move around causing it to get stuck.
Old Dec 16, 2008 | 02:31 PM
gotanswers's Avatar
float out of adjustment or your fuel pecock might be clogged lemiting fuel to carb
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
