Can you just replace one half of engine case
Old Dec 13, 2008 | 11:22 PM
atowley's Avatar
Default Can you just replace one half of engine case
I just tore the engine out of my 98 polaris magnum 425 to repair the crank case half. I have already tore the engine down and have a donor case half for it. My question is someone told me that the case halves are a matched set. Meaning I can't mix and match two case halves from two different engines. The crank holes won't line up because they are line bored from the factory??? Is this at all true or can I do like I was doing and go ahead and bolt it back together with the new case half. Thanks for any help.
Old Dec 13, 2008 | 11:51 PM
ftwflh's Avatar
You can mix cases they sell them in 2 parts
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
norm440EX
Feb 28, 2000 05:05 PM
