Tips to remove front driveshafts?
Old Dec 14, 2008 | 07:28 PM
brewersfan's Avatar
Default Tips to remove front driveshafts?
I have a '97 Xpolorer and would like to remove the front eccentric. Both shafts need to be removed however, I cannot tap the roll pins out - won't budge. With the limited angles that you can position the punch at it is hard to strike it with any kind of force.
Any tips?
Old Dec 14, 2008 | 07:29 PM
onesavage's Avatar
i used a air chisel with a point puch end
Old Dec 27, 2008 | 06:47 PM
brewersfan's Avatar
I found the best way to do this is from the front of the machine, line the roll pins up horizontally and come at through one of the holes in the frame. On the left side the front eccentric pinch bolt is in the way and needs to be removed. Use a punch the exact size of the roll pin, a heavy hammer and a lot of force.
Old Dec 27, 2008 | 07:28 PM
ftwflh's Avatar
It is also easyier to tip the bike up on the rar end to work on this.
Old Dec 27, 2008 | 07:32 PM
onesavage's Avatar
my sportsman dont like that angle,she fills the air box with oil
Old Dec 27, 2008 | 07:34 PM
ftwflh's Avatar
I he gets oil in HIS air box he is in trouble being it is a 2stroker <wink>
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
