2007 POLARIS 800 X2 OUT OF WARRANTY NO 4WD
Old Dec 14, 2008 | 09:55 PM
2blue's Avatar
Default 2007 POLARIS 800 X2 OUT OF WARRANTY NO 4WD
Anyone help me here...
Gauges show 4wd and machine is stuck in 2wd
If I reverse pressing the override button then i have 4wd..BUT only in reverse
Old Dec 14, 2008 | 10:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
any grinding while its in reverse? just wondering if its the dredded roller cage?
Old Dec 15, 2008 | 12:03 AM
dodge33's Avatar
the reverse override switch could be malfunctioning. check for any codes on the lcd display and see if the atv tells us anything!
Old Dec 15, 2008 | 08:53 AM
HIGHOCTANE's Avatar
Verify you are in fact getting voltage to the AWD coil. If the icon is present you probably are,but check it with a meter. If you are,but it isn't engageing then you have a mechanical issue. Like stendori said,might be a roller cage problem. Check the fluid level as well,the front diff is very picky about having the proper fluid level.
Old Dec 18, 2008 | 03:59 AM
2blue's Avatar
What is the roller cage? And where is the AWD coil?
The 4wd only works in reverse.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Captjay
Jul 23, 2015 12:33 PM
Scottma518
Jul 10, 2015 12:42 AM
Sjrpp
Jul 5, 2015 09:04 PM
