overheating question
Old Dec 15, 2008 | 03:28 PM
DMedlin's Avatar
Default overheating question
got an '06 bruin. last 2 times i have ridden a long time, @ 4 hours or so, my oil temp light came on. the oil level is OK, the cooling fan does come on. Light comes on right after riding at or close to full throttle for 10 minutes or so. What could be my problem?
Old Dec 15, 2008 | 08:07 PM
cherokee99's Avatar
you need to check the if the fan runs atall. if you can hotwire the fan, and it works, then you have a temp sensor that is not working.
Old Dec 15, 2008 | 08:37 PM
91Warrior357's Avatar
dirty radiators can do that, or if you got old crummy oil that can also cause an overheating issue.
Old Dec 15, 2008 | 10:24 PM
cherokee99's Avatar
the bruin is 350cc, oil cooled if im not mistaken. but the fan should kick on even if the oil is gunky. true 91warrior357, if the oil cooler is dirty that would impeed cooling as well
Old Dec 16, 2008 | 08:36 AM
ROBBASS's Avatar
How is your jetting?, proper jetting insures cooler cylinder temps also helping regulate overall engine temp.
Old Dec 18, 2008 | 12:28 AM
cherokee99's Avatar
from what iv seen if your too lean, and running too hot, your exhaust pipe will heat up and be glowing red hot. but if its only overheating at high rmp's its more likely an oil prob, if your header isnt glowing!
Old Dec 18, 2008 | 08:57 AM
ROBBASS's Avatar
Also is there any mud or dirt packed in your oil cooler or on or around your motor, I have seen where oil coolers and radiators get mud packed in them and that will kill an engine, it will cause them to hold a ton of heat.
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
2many2ride
Sep 27, 2015 04:35 AM
bigred20653
Sep 19, 2015 02:11 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
