Changed out battery on the 700
Old Dec 16, 2008 | 09:12 AM
Kerbbirds's Avatar
Default Changed out battery on the 700
Battery quit on my 03-700, bought a new gell filled for $100 bucks, they have a 2 yr warranty and were a little cheaper than a wet battery, seeems to turn over better than it has in a long time. What a pain to get the old one out, had to make a strap out of an old tie down andhook to the battery post bolts, then use a come along from the roof of my garage to pull it out,I was lifting the back of the machine with the battery bolts, had to pry and use a hammer around the battery box, a little mud and water will really stick things.
Old Dec 16, 2008 | 09:15 AM
user493's Avatar
Moto Psycho
I know dirt makes them stick but did the battery swell up too? I had that happen once. I think it froze when it was run down.
Old Dec 16, 2008 | 09:20 AM
Kerbbirds's Avatar
Dont think it swelled or froze, my garage is heated, awfull tight fit is all, by the way my thermometer says 12 below and its 6:25 am in Douglas Wyo, glad thje atvs arent sitting outside.
Old Dec 16, 2008 | 11:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i took mine out of my 800 this year and had to pry it out w/ 2 bars as the dirt and mud was cake n big time. what a tight fit for sure.
Old Dec 16, 2008 | 04:25 PM
Wheels47's Avatar
I took mine out a couple of months ago and I had the same problem. I had to pry it out and there was some dirt that was holding it in. You might take it out occasionally and clean it out this might help.
Old Dec 17, 2008 | 03:42 AM
Dearlh's Avatar
:Yep I replaced mine this past summer too. Went with the AGM type. Mine too was a %$#@& to pull out, was able to screw heavy cable onto the posts to wrestle it out. The bottom of the box was covered in crud.
Old Dec 17, 2008 | 09:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
would have been better if they could have designed it w/ an open concept like the side mounted batteries. or even an open style bottom maybe w/ more holes to drain out the crap better.
Old Dec 17, 2008 | 02:52 PM
Dearlh's Avatar
[img]i/expressions/face-icon-small-disgusted.gif[/img]Ya that or make the box alittle bigger so you have some wiggle room. Glad thats not a regular part of routine maintainence
Bratman2
Aug 6, 2022 01:42 AM
Cummins Driver
Sep 11, 2019 01:22 PM
cody500ho
14
Aug 14, 2015 05:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
