do i need rear wheel spacer???help
Old Dec 17, 2008 | 04:39 PM
yellow bird's Avatar
Default do i need rear wheel spacer???help
I HAVE A 97 300 4WD
I WOULD LIKE TO PUT 27-11-14 SWAMPLITES, WITH ITP 112 RIMS
DO I NEED REAR WHEEL SPACERS??? ANY HELP THANKS
Old Dec 17, 2008 | 11:34 PM
cherokee99's Avatar
spacers, mabe. lift YES! you could mabe get 26" tires on a stock 300, but 27 i doubt. come to think of it you may have to have spacers, the tires might interfear with the break cables.
Old Dec 18, 2008 | 10:23 AM
HEY CHEROKEE 99
THANKS FOR FOR REPLY. U MUST BE A JEEP FAN, I WORK FOR A CHRYSLER DEALER, SERVICE ADVISOR. I TRIED EM OUT AND THEY FIT, I COULDNT BELIEVE
IT!! THE REAR TIRES ARE IN ABOUT AN INCH OR SO, BUT OH WELL. I PICKED IT UP CHEAP, REAL CHEAP. SO ITS MOSTLY FOR A MUD TOY. THANKS FOR THE HELP THOUGH
Old Dec 18, 2008 | 06:23 PM
BlueRubie's Avatar
well first mount them up and see most thought i needed a lift and spacers for my machine. . .
But i did not need them. . .
My 27x10-12 fit my stock front rims and cleared everything i had no rubbing anyplace. . .
My 27x12-12's fit on my stock rear rims and they had no clearence issues on the rear of the machine. . .
But i'm guessing the 300 is a bit smaller unit more like the size of a rancher ?
Mike
Old Dec 19, 2008 | 12:55 AM
cherokee99's Avatar
why yes i am a HUGE jeep fan! and part native american, so cherokee has a double meaning. you may still have a problem with bottoming out the tires on the fenders though, when you hit a bump or have a load on the rack. so you might still need a lift. but have fun mudding with it!
Old Dec 22, 2008 | 09:57 AM
thanks cherokee 99. you guys were right. the tires clear fine on pavement, but in the holes i thought the front fenders were being ripped a apart. i have 25' mud machines and a set of 12' stock rims off a foreman. BUT I HAVE A BIGGER PROBLEM. SAT NIGHT WAS THE 1ST REAL RIDE TIME AND I HAD A BAD CLANKING SOUND COMING FROM HE REAR, ONLY WHEN RIDING THE TRAILS, ON SMOOTH PAVEMENT NO NOISE??. WE JACKED THE QUAD UP AND FOUND THE RIGHT REAR WHEEL HAS A LOT OF PLAY!!! MAKES NOISE FOREWARD, BACKING UPMOSTLY SPEEDS AROUND 2ND, 3RD GEARS, TRAILS TO SHORT FOR HIGHER GEARS. WHAT DO U GUYS THINKS!!!
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DFWSRT8
Aug 20, 2015 09:24 AM
Bergmann
Aug 13, 2015 03:51 PM
chuck1177
Aug 11, 2015 03:22 PM
