cv boot install
Old Dec 19, 2008 | 11:26 PM
yard_dawg's Avatar
Default cv boot install
ok guys need some help here. got a 97 sportsman 500. got a small tear in my right front boot. can any one give some steps that i can follow to change this out,and make it easier on me. I have never had to change one out before so i am sorta lost here in the proper way and steps to do this. thanks a lot
Old Dec 20, 2008 | 12:00 AM
Koerbs's Avatar
Take off the tire, and hub. Pop the axle by jerking on it or pounding on it with a rubber mallet. Undo the metal clips with a pliers, clean the grease with brake parts cleaner. Pop out the clip inside the cv joint, you will notice it, it holds the shaft in the ball bearing unit. Clean it up, put the grease in the the center of the cv joint, put the rubber boot on the shaft, put the clip in its spot, slide the axle shaft in the cv joint and it will snap together, and slide the boot over the cv joint, put the new clamps on it and a pliers will re clamp them just fine. As you get into it you will get a feel for it.
Old Dec 20, 2008 | 08:14 AM
yard_dawg's Avatar
ok, thanks for the help, gonna give it a try.
Old Dec 20, 2008 | 02:59 PM
tripleR's Avatar
Check on You Tube, there is a guy who takes you through step by step.
Old Dec 21, 2008 | 12:03 AM
yard_dawg's Avatar
i did and it did help thanks, but was wondering what steps do i take to remove the shaft from the bike,
Alex G.
Sep 11, 2017 11:38 PM
2many2ride
Sep 27, 2015 04:35 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
