1987 HONDA 250X WONT FIRE!!!!!
Old Dec 21, 2008 | 03:05 AM
dustin450's Avatar
Default 1987 HONDA 250X WONT FIRE!!!!!
I just bought a 1987 honda 250x from a buddy that had got tired of workin on it its just had a fresh powder coat job on the frame and had stator problems before getting the bike (restored) if you wanna call it that.SO he put a new/used stator on it ran for about 10 mins and has never fired since.We checked all of the stator wires there all getting fire also spark plug and plug wire and coil.Also there is no key just the kill switch that came on it. ANY SUGGESTIONS???
Old Dec 21, 2008 | 07:12 PM
TNHondaMan's Avatar
did he kill it at kill switch when he killed it or did it just die? if your plug is firing in the cylinder,only a few things it could be.
Old Dec 23, 2008 | 01:01 AM
dustin450's Avatar
He said he had just got it runnin and took it down a field road and thats when it died but yea it just cut off he didnt go into any details about if it was cuttin out or doing anything out of the ordinary according to him just quit!!! But when i checked the stator i found that the flywheel had a little pinhole in it and a raised spot but couldnt see anywhere that it had rubbed and i when i checked the stator wires they were pulling anywhere from 60 to 70 volts.
Old Dec 23, 2008 | 04:20 PM
TNHondaMan's Avatar
does it have a pulse generator?
Old Dec 24, 2008 | 01:06 AM
dustin450's Avatar
its got a magneto stator, i had a guy tell me that it could be the erectafire could that actually keep it from firing?
Old Dec 24, 2008 | 06:43 AM
HondaMechanic's Avatar
1987-88 250x components
Ignition tests
Old Dec 24, 2008 | 04:18 PM
TNHondaMan's Avatar
i have a 300ex that did the same thing,i changed out the stator,pulse generator, rectifier (which just converts ac to dc voltage and nothing else) fuse box and fuses and it fired right up. Sounds like you simply have a shortage problem or your ignition system is jacked up. Will it even hit a lick?
Old Dec 25, 2008 | 01:31 AM
dustin450's Avatar
Thanks for the diagrams and all the info guys gonna work on it this weekend see what happens!!
Old Dec 28, 2008 | 05:26 PM
Phlogiston's Avatar
The CDI unit failed on mine. It became very intermitant then died.
Old Jan 2, 2009 | 10:17 PM
TNHondaMan's Avatar
did you get your quad going man?
