Warrior will not run off idle
Old Dec 23, 2008 | 09:05 PM
silkworm's Avatar
Default Warrior will not run off idle
I have a 1997 Warrior & it will not run over an idle, I have changed the carb needle, cleaned carb, replaced stator, cdi box & coil & it still will not take any throttle, it just dies... any ideas?
Old Dec 23, 2008 | 09:36 PM
raptor#420's Avatar
mixture screw?
Old Dec 23, 2008 | 10:30 PM
400ex madman19's Avatar
if you just turn up the idle screw it should run fine
Old Dec 23, 2008 | 10:58 PM
Raptor450's Avatar
The 1st thing I would check is them raggidy parking brake sensors.
Old Dec 24, 2008 | 04:26 PM
coppermouse's Avatar
I had the same problem, the stupid parking brake sensor switch, on the end of the clutch handle
Old Dec 24, 2008 | 05:25 PM
Funeral Home guy's Avatar
Try your Air/Fuel mixture screw.
Nosniborpapa
Sep 12, 2015 05:54 PM
Jaymc
Sep 11, 2015 07:45 AM
Minimod
Sep 10, 2015 09:20 PM
Hw00d
Sep 10, 2015 08:53 AM
Minimod
Sep 10, 2015 08:03 AM
