help with winch???
Old Dec 27, 2008 | 05:41 PM
michael l's Avatar
Default help with winch???
I've seen some of you guys talking about synthetic winch ropes. What all do I need to get to convert my winch over to have rope on it, and where is the best place to get it from. Called one of the local part stores and they can order the synthetic rope but they do not know what all I need to switch it over. It is a 2.5ci Warn.
Old Dec 27, 2008 | 05:45 PM
I've seen alot of discussion on this one, Michael. They recommend getting a new fairlead as well when you buy the winch. Nicks and scratches in the old fairlead will deteriorate the synthetic much more quickly than the wire rope.
Old Dec 27, 2008 | 05:49 PM
michael l's Avatar
So all I need to get then is a new fairlead and the synthetic rope? Is there a kit that has both, where can I get it at, and about how much will it cost for both parts?
Old Dec 27, 2008 | 05:51 PM
Not sure on your other questions. I haven't done the change yet due to my winch being in good shape right now.
Old Dec 27, 2008 | 05:53 PM
JCDEYO25's Avatar
Moose is correct but as long as the rollers are burr free you should be ok........I switched to a composite hawse fairlead when I initially bought my synthetic but went back to my roller....You're gonna want a 3/16" by 50', some get 75' on the drum but I put 50'...Keep an eye out when your taking the last few feet of wire cable off as there will be a small "button" that you'll need for the synthetic when you respool......Keep track of the way the wire comes off and put the syn. on the same direction...There's a few different types of syn. out there...just to name a couple......Amsteel and Masterpull......Feel free to ask more questions when you're ready to do it...If you're gonna be plowing with it I'd suggest a shorter piece like I have maybe 10'...
John
Old Dec 27, 2008 | 05:56 PM
michael l's Avatar
Thanks for the help. The only reason that I would like to switch is because when I got the bike the winch was only about 6' long. It helps getting me out but I have to use my strap with it to reach something. Wish it was longer alot of times.
Old Dec 27, 2008 | 05:58 PM
michael l's Avatar
Thanks John,
But in southern Arkansas we don't get a whole lot of snow to speak of. Do you know about how much it will cost to switch over to rope.
Old Dec 27, 2008 | 06:00 PM
JCDEYO25's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: michael l
Thanks for the help. The only reason that I would like to switch is because when I got the bike the winch was only about 6' long. It helps getting me out but I have to use my strap with it to reach something. Wish it was longer alot of times.</end quote></div>
That was probably used for plowing...A short section is used because it doesn't get wrapped as many times around the drum.....When you plow there's alot of in and out and a long section tends to get "sucked" in towards the center of the drum.........A short piece remedies this......
John
Old Dec 27, 2008 | 06:13 PM
JCDEYO25's Avatar
Here's what you should be looking for......There are others out there this is just an example...
http://www.amsteelblue.com/item.cfm?itemid=44753
John
Old Dec 28, 2008 | 12:16 PM
michael l's Avatar
Thanks for the help..
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
