07 KAWASAKI BRUTEFORCE 650
Old Dec 28, 2008 | 12:49 AM
CUSTIMHOME's Avatar
Default 07 KAWASAKI BRUTEFORCE 650
CRANKS RUNS FOR A FEW SECONDS AND DIES ALSO 2WD/4WD FLASHES
Old Dec 28, 2008 | 02:39 AM
cherokee99's Avatar
you need 3 things to run a motor.
1. compression
2.spark
3. propper fuel/air mix
have you used the choke atall? check your spark plug for a good strong spark. if it runs for a bit then your compressions good. clean your carb, if you dont have a carb on the bike it cound be your ECM unite. and try bumping up the idol speed.? but if its fuel injected run some seafoam threw it. might be a dirty injectur? if its still under warrenty take it back to the dealer
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
shimanok2
Jan 29, 2016 07:37 PM
wendal
Sep 15, 2015 01:50 PM
