2000 Kawasaki KVF400 4x4 exhaust overheating
Old Dec 29, 2008 | 06:55 PM
Baker88's Avatar
Default 2000 Kawasaki KVF400 4x4 exhaust overheating
I have a 2000 KVF 400 4x4 and after a short amount of use the exhaust overheats. It gets so hot that the fenders have began to melt. Does anyone have any idea of what the problem could be?
Old Dec 30, 2008 | 12:24 AM
cherokee99's Avatar
if its more your heared pipe then you are jetted too lean. you really need to rejet the main, and at the least adjust your pilot jet richer. this is provided there is nothing blocking your exhaust. it would also be a good idea to clean your carb. just get in the bowl and hose it down with carb cleaner. het the jets especially well!
you will have to buy a jet kit, but the pilot jet you can do yourself. the pilot jet is located on the bottom of the carb, outside the carb bowl, twords the engine. its a small brass skrew. if its a mikuni carb then skrew the pilot IN 1/4 turn at a time. if its a khein carb you skrew the pilot OUT 1/4 turn at a time. sorry i dont know off hand if the 400 has a mikuni or khein...
i hopr this helps your problem
Old Dec 30, 2008 | 02:11 PM
Baker88's Avatar
We installed a new exhaust and nothing changed but will try cleaning the carb and the pilot jet
Old Dec 31, 2008 | 12:51 AM
cherokee99's Avatar
if your carb is dirty that will stem the flow of fuel in the carb. this could cause you to run lean
good luck
Old Jan 10, 2009 | 09:48 PM
Baker88's Avatar
hey, done what you said but still got the same problem, the fenders melt back near the exhaust next to the foot rest on the bike. please help with any ideas!!
slowgsxr97
Mar 18, 2022 03:40 AM
colt1126
Aug 18, 2015 08:27 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
