two batteries
Shouldn't be to hard to do...same as in a diesel truck...just hook in parallel as in pos to pos and neg to neg. I don't see it causing any problems other then may take a bit longer to charge the batteries, not really sure what amperage is output by the charging system.
I have been looking through the manuals but I seem to remember reading somewhere that the 800 Charging system is like 300W. Maybe OPT will chime in on that.
With two batteries I would be more concerned about the Voltage Regulator. imo
The key factor in all of it is the "Break Even" point. Having the engine turning enough RPMs that the Alternator can overcome the load on the system. The manual describes 1500 RPM lights off, 2000 RPM lights on.
ymmv.
ymmv.
<div class="FTQUOTE"><begin quote>Originally posted by: tipo176
Mine gives 500W @ 3000 rpm.</end quote></div>
500 is correct. i dont know if i would even attempt doing it w/ the electronics being so senative. these bikes arent designed to put alot of juice in the charging department, and like has been mentioned might overload it.
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
