two batteries
Old Dec 29, 2008 | 09:04 PM
rr-john's Avatar
Default two batteries
does anybody have two batteries hooked up or know how too
Old Dec 29, 2008 | 09:09 PM
G.A.S.'s Avatar
To maintain the correct voltage you will want wire them so the batteries are in parrallel. Never done it myself but is what you will need to do. Have you considered a battery with more amps??
Old Dec 29, 2008 | 09:15 PM
sxrfun's Avatar
Shouldn't be to hard to do...same as in a diesel truck...just hook in parallel as in pos to pos and neg to neg. I don't see it causing any problems other then may take a bit longer to charge the batteries, not really sure what amperage is output by the charging system.
Old Dec 30, 2008 | 12:14 PM
BigBros_Farmtoys's Avatar
I have been looking through the manuals but I seem to remember reading somewhere that the 800 Charging system is like 300W. Maybe OPT will chime in on that.
With two batteries I would be more concerned about the Voltage Regulator. imo
The key factor in all of it is the "Break Even" point. Having the engine turning enough RPMs that the Alternator can overcome the load on the system. The manual describes 1500 RPM lights off, 2000 RPM lights on.
ymmv.
Old Dec 30, 2008 | 02:12 PM
tipo176's Avatar
Mine gives 500W @ 3000 rpm.
Old Dec 30, 2008 | 04:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: tipo176
Mine gives 500W @ 3000 rpm.</end quote></div>
500 is correct. i dont know if i would even attempt doing it w/ the electronics being so senative. these bikes arent designed to put alot of juice in the charging department, and like has been mentioned might overload it.
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
