2002 Honda ATV Rubicon Shifting Problem
Old Dec 30, 2008 | 09:55 PM
Mickey1's Avatar
Default 2002 Honda ATV Rubicon Shifting Problem
Can someone please point me in the right direction. This has been an ongoing problem with the ATV and I have spent a couple of thousand on repairs alone with still NO results.
When I put the machine into reverse it starts to sputter and backfire, then when I put it into neutral, the D1, D2 and ESP lights will flash simultaneously and I am unable to change gear selections except into the reverse mode. If I reset the computer, as long as I stay driving forward the machine works fine. If I put it into reverse the problem appears.
The machine is back in the shop again after 3 hours of use and this time 900 dollars Canadian later. I have seen a few people on this forum with the same problem. Any suggestions or recommendations would be appreciated.
I have changed:
-the ICU (3 times)
-high speed sensor
-reverse switch (both switches)
-the little motor on the left hand side (2 times)
This machine has been nothing but problems and I have had no support from Honda and the 2 dealers I have regularly been bringing the ATV to.
Feel free to answer if you can
Thank you
neilbedwell
Nov 10, 2018 11:02 AM
AtvManiac78
Jul 11, 2015 03:20 AM
ROWALKER
Jun 15, 2015 05:38 PM
lovinhonda
Jan 25, 2000 09:17 PM
