polaris sportsman 700 fan fuse
Old Dec 30, 2008 | 11:14 PM
joecat07's Avatar
Default polaris sportsman 700 fan fuse
whats up guys. got a sportsman 700 camo and gotta alittle problem maby you guys can help me with. Recently i noticed the fan would not come on like it normally does.The machine didnt run hot but i knew i had a problem. I removed the fAN to observe that some wires were burned in the connector, I replaced the fan but it still wont come on. Is there a fan fuse on this bike if so where is it. There are four fuses under the radiator cover but they are not labeled. Any help is appreciated
Old Dec 31, 2008 | 12:24 AM
eggenz7's Avatar
your temp sensor could be out. if it doesnt close the circuit then the fan will not come on. water level too low could cause this too. to check the sensor unplug the two wires running to it and use a short piece of scrap wire to jump across those two wires. fan should kick on unless there is another sensor that im not aware of.
Old Dec 31, 2008 | 01:31 AM
joecat07's Avatar
where is the temp sensor located? i jumped fire off the ole fan and it would barely come on. Should i do the same this time?
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
