knockin
Old Dec 31, 2008 | 09:59 AM
juttin_15's Avatar
Default knockin
if i bored my atv 20 over and didnt jet will that cause the piston to hit the valves?
Old Dec 31, 2008 | 10:44 AM
Doctorturbo's Avatar
GOT BOOST!
Default knockin
No. Boring has nothing to do with valve to piston clearance. And jetting REALLY has nothing to do with valve to piston clearance.
Old Dec 31, 2008 | 10:49 AM
juttin_15's Avatar
Default knockin
well my piston it hitting the head
Old Dec 31, 2008 | 04:54 PM
HondaMechanic's Avatar
Default knockin
Did you use stock size head gasket or the OS (over size) head gasket .. Your piston is probably touching the head gasket ..
Old Dec 31, 2008 | 07:58 PM
GOT BOOST!
Default knockin
<div class="FTQUOTE"><begin quote>will that cause the piston to hit the valves? </end quote></div>
<div class="FTQUOTE"><begin quote>well my piston it hitting the head </end quote></div>
Did the piston hit the head or the valves? BIG difference.
If the piston hit the valves: It could be:
#1 Excessive piston to bore clearance.
#2 Wrong piston.
#3 Excessive wrist pin to piston clearance.
#4 Bad con rod bearing.
#5 Wrong cam timing.
#6 Too big of cam.
#7 Wrong head/base gasket crush.
#8 Too much taken material taken off of head (That's all I can think of now!!)
If the piston hit the head: It could be:
#2 Wrong piston.
#5 Wrong head/base gasket crush.
#6 Too much taken material taken off of head (That's all I can think of now!!)
Or it could be none of these and the piston is hitting the gasket like HondaMechanic said.
Old Jan 2, 2009 | 03:30 PM
juttin_15's Avatar
Default knockin
ive pulled the head and the piston has indentions where the valves line up with the piston, if i didnt put on a thick enough gasket will it cause it
Old Jan 2, 2009 | 03:54 PM
budedm's Avatar
Default knockin
Too thin of a gasket COULD cause it. It depends on how much clearance there is in the stock configuration. Did you do anything else besides boring it and putting in a bigger piston? You should use the same thickness gasket but with a bigger ID to match the new bore dia.
Old Jan 2, 2009 | 04:13 PM
johnboy27's Avatar
Default knockin
<div class="FTQUOTE"><begin quote>Originally posted by: juttin_15
ive pulled the head and the piston has indentions where the valves line up with the piston, if i didnt put on a thick enough gasket will it cause it</end quote></div>
those are valve reliefs they are there from the factory.
Old Jan 3, 2009 | 12:59 AM
juttin_15's Avatar
Default knockin
what if i use silicone on each side of the gasket?
ed333
Dec 4, 2013 02:10 PM
bnburkett
Feb 21, 2009 09:54 AM
tura45
Aug 20, 2008 07:54 PM
motorider7
KTM
22
Jan 16, 2003 04:46 PM
