Big Bear 250 Neutral Drop
Old Jan 1, 2009 | 08:01 PM
SlickVic107's Avatar
Default Big Bear 250 Neutral Drop
Ok so i know its not the smartest thing but its sooo much fun. How hard is it really on the clutch,trans,gears,etc if you are in nuetral, rev it up high and drop it in gear so that will pull huge wheelies?
Old Jan 1, 2009 | 08:27 PM
mindblock's Avatar
Very hard can strip gear.... you can place in 1st gear and pullup on lever till you hit neutral then drop it.
Old Jan 1, 2009 | 08:33 PM
So what if i go to 2nd...then push down to go to first and hold it there so its "not in gear", rev, and then let up on lever?
Old Jan 1, 2009 | 08:38 PM
mindblock's Avatar
Will not see a diff.... When in first gear or second(not sure if you got enought power) you pull up on shift lever just alittle till you hit like a neutral but don't pull tomuch or you will just change into second gear. this info is not that great for your bike tho.
Old Jan 1, 2009 | 08:45 PM
Ok thanks, its not an everyday thing. I use it mostly for transportation while im drag racing, cars not atvs, and every new years day my large extended family gets together and rides all day. Just needed how much i could get away with before major damage. Thanks again.
2quiker
Mar 22, 2022 08:36 PM
awer1968
Sep 8, 2015 11:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Pahuntman
Sep 5, 2015 11:07 AM
Canamaniac!
Sep 4, 2015 06:44 PM
